pilar not wrapping
Zendrix
Please see this example:
I have a composite wall made of stone core and 2 plaster skins.
1. I insert a pilar made of the same material as the core (stone);
2. I choose the wrapping method required;
But the plaster wrapping around the pilar its simply not happening. Pilar and wall are in the same layer, so layer values should not be colliding, whats missing?
Thanks,
AC28 . LeNovo Y520 Intel Core i7-7700HQ @ 2.80GHz 8GB RAM. Windows 10 Home
Make sure the plaster skin in the wall composite is not set as a 'core'.
4 REPLIES 4
vlahtinen
Check if View → On-Screen View Options → Clean Wall & Beam Intersections is off.
Zendrix
Hey vlahtinen
It was on. i turned it off and the only thing that changed was that the bottom line became thicker.
that was it!
Barry, ur a savior!
