License outage
Dear Customers, We are facing with an outage in our services in Azure. You may experience issues with the Azure-based functions, like licensing, BIMcloud SaaS, Learn Portal. We are working hard on this issue to make it fixed as soon as possible. Thank you for your patience.
if im at the end of the construction documents for a project and i want somebody to help out!! turning the pln file into a teamwork file..is it gonna mess up the view setup? or the pm sheets set up? cuz of not reading anylonger from the pln?,,now a tmwk extension file??? or
i can go teamwork anytime and all wd be beautiful and peaceful for ac and pm??
sharing ur knowledge regarding this lack of experience of mine is greatly appreciated
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
You're view sets will come across fine. In plotmaker you will need to re-establish the links as the file name will have changed. This is not a problem if you have only the one file linked into plotmaker. Just select the files and click "read all from".
