pln to teamwork file
Rakela Raul
if im at the end of the construction documents for a project and i want somebody to help out!! turning the pln file into a teamwork file..is it gonna mess up the view setup? or the pm sheets set up? cuz of not reading anylonger from the pln?,,now a tmwk extension file??? or
i can go teamwork anytime and all wd be beautiful and peaceful for ac and pm??
sharing ur knowledge regarding this lack of experience of mine is greatly appreciated
MACBKPro /32GiG / 240SSD
AC V6 to V18 - RVT V11 to V16
You're view sets will come across fine. In plotmaker you will need to re-establish the links as the file name will have changed. This is not a problem if you have only the one file linked into plotmaker. Just select the files and click "read all from".
Rakela Raul
thx millard...not a big deal then ..will do
...but i will remember you if it goes sour..just kidding..thx a lot sir
