2005-07-01 09:37 AM
2005-07-01 12:23 PM
2005-07-01 02:47 PM
Millard wrote:
... What we have now works fairly well. I can agree that the update speed could be improved, but for the most part I feel that Graphisoft has gotten this one right.
Our files always have at least two projects that are imported to PM; a site and building model. This would mean always using the standalone version.
2005-07-02 07:44 AM
I cannot see wasting the time and energy to incorporate PM into the AC application, while also maintaining a stand-alone version.Well, in fact, there is no wasting time and energy on current PM as the major tools don't work in it! But it would be, if GS would try to double all the code separately for AC and PM. PM should definitely be incorporated into AC somehow as a 'semi-standalone option' that runs FULLY on AC core code, however with its own file format and options to import another drawings from different plns. Sort of having the Start window with options to AC mode, PM mode (undongled) or both (sharing and switching through the navigator within the pln). Let's face it, it's a bit silly to open background AC, then PM, reload all the libraries again without all good AC features and having so 3 applications running (including source file AC) and munching comp resources/speed. It requires a completely new approach for sure. I just wonder how it works with Revit and/or other applications. They have had to address this problem somehow. At the moment it's a bit paranoic solution.
2005-07-28 11:01 PM
2005-07-28 11:01 PM
2005-07-29 07:52 AM
The biggest problem will be "TOLD YOU SO!" from the Revit camp ...Well, I wouldn't give a ... about this one. If it works and it's more beneficial for the workflow then the current status let's adopt that asap!
2005-07-29 09:07 AM
2005-07-29 02:53 PM
2005-07-31 08:15 PM
