plotmaker vs archicad 10
I have just started to play around with archicad 10. Now that you can now plot directly from archicad 10, do I have to recreate all my layouts in AC 10 or is there a method of pulling in layouts from Plotmaker 9
4 REPLIES 4
TomWaltz
The Archicad 10 Help Menu includes a new feature guide with about 20 pages of detail on everything you ever wanted to know about converting projects from Archicad & Plotmaker 9 to Archicad 10.
The short version is yes, it's possible, and should take about 10 minutes to convert.
Tom Waltz
Thanks Tom reading through it right now
I found it helpful to open the most current plotmaker file with AC10. Then the PM master layouts are easy to cut and paste and re-create in AC10
Djordje
