aryastark
problem: hiding column intersection line
hello murghulis,
i want this line not showing.
->model view option checked. [not working/nothing found]
->checked settings dialog. [not working/nothing found]
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
1 Solution
Lingwisyer
Guru
Oh? I thought they changed this in 23 with the column rework. Apparently not...
Anyway, you can get around this by overlapping a wall with the same building material and width as your columns at the junction, if they are freestanding.
Ling.
Go to post
5 Replies 5
Lingwisyer
Guru
Extend the right column so that it intersects with the left? This will offset you column marking, if that is important.
Unless things intersect, you will get an edge line and unlike walls, columns will not automatically intersect.
aryastark
Ver: AC23
Memory: 16384MB RAM
Columns don't intersect (trim) like walls do.
Lingwisyer
Guru
Ling.
Or create a single 'T' shaped complex profile column.
Or if they don't need to actually be long columns, use walls instead?
