quick selection and roofs in AC22
Good morning,
AC22, the quick selection tool (magnet) does not work on roofs in plan view/model view. The only way I can select the roof is by the edges. Does anyone have the same problem?
Thanks,
Jim
James B
In AC22, surface selection on Overhead elements was removed to give priority to surfaces of Uncut elements below (on Floor Plan).
https://helpcenter.graphisoft.com/knowledgebase/83610/
Under "Selection" section (need to scroll down a bit).
James Badcock
Graphisoft Senior Product Manager
4 REPLIES 4
James B
James Badcock
Thanks, that answered my question.
Jim
So there is no way to select overhead elements with the magnet any more?
Dave Brach/architect
AC26 MBP OS Ventura
AMD Radeon Pro 5300M 4 GB
Intel UHD Graphics 630 1536 MB
It seems not, because the overhead portion does not have a fill any more.
You can still click on the ridge/hip lines.
