ā2005-12-05 11:02 PM
ā2005-12-06 04:07 AM
miker wrote:Regretfully none, except manual (read the coordinates, calculate).
Is there any way to measure an area in plotmaker?
ā2005-12-06 08:33 AM
ā2005-12-06 12:13 PM
ā2005-12-06 12:58 PM
ā2005-12-06 02:14 PM
miker wrote:It sounds like what you want to do would be trivial in Archicad, but impossible in Plotmaker. Why would Plotmaker be the right way?
When i make the plan of field for example
Of course i can do that in AC and this is the right way but once there is raster tool in plotmaker why not![]()
Thanx
ā2005-12-06 10:05 PM
ā2005-12-07 04:04 AM
miker wrote:The PlotMaker is not for doing any design work, only for layouting.
In AC when you make a raster in your plan, you can also set it to display the area of the raster.
But this is not possible via Plotmaker
The right way is AC not Plotmaker
ā2005-12-07 01:05 PM
Djordje wrote:I'll keep that in mind
All your design and drawing work should be done in ArchiCAD.
Take that as a rule, your life will be much easier!
