‎2005-12-05 11:02 PM
‎2005-12-06 04:07 AM
miker wrote:Regretfully none, except manual (read the coordinates, calculate).
Is there any way to measure an area in plotmaker?
‎2005-12-06 08:33 AM
‎2005-12-06 12:13 PM
‎2005-12-06 12:58 PM
‎2005-12-06 02:14 PM
miker wrote:It sounds like what you want to do would be trivial in Archicad, but impossible in Plotmaker. Why would Plotmaker be the right way?
When i make the plan of field for example
Of course i can do that in AC and this is the right way but once there is raster tool in plotmaker why not![]()
Thanx
‎2005-12-06 10:05 PM
‎2005-12-07 04:04 AM
miker wrote:The PlotMaker is not for doing any design work, only for layouting.
In AC when you make a raster in your plan, you can also set it to display the area of the raster.
But this is not possible via Plotmaker
The right way is AC not Plotmaker
‎2005-12-07 01:05 PM
Djordje wrote:I'll keep that in mind
All your design and drawing work should be done in ArchiCAD.
Take that as a rule, your life will be much easier!
