2004-01-19
03:35 PM
- last edited on
2023-05-25
05:17 PM
by
Rubia Torres
2004-01-19 06:38 PM
2004-01-19 09:09 PM
Til wrote:I work in real units too, using 'mean sea level' as zero, with the site being set at zero and ground floor at whatever is level is desired. I presume you prefer to 'level' from ground floor = 0.00.
This was usefull when you needed to work in real values : giving the real height to any point, and the zero as reference level to the mesh. Instead of getting the terrain's foot at the sea level you could put it upper with this negative value. With ArchiCAD 81 it's now impossible
2004-01-19 11:29 PM
2004-01-20 10:26 PM
