setting the mesh tool
Hi, a question about the mesh tool (or terrain tool ?)
Formerly (untill v70) a very usefull bug allowed us to give a negative value to a mesh's height.
This was usefull when you needed to work in real values : giving the real height to any point, and the zero as reference level to the mesh. Instead of getting the terrain's foot at the sea level you could put it upper with this negative value. With ArchiCAD 81 it's now impossible !
Ok with the 3D boolean operator you can solve it but is there a faster and easier solution ?
4 Replies 4
I'm sorry, I'm scatterbrained, my question isn't in the good chapter, it should be in specific questions and problems. Could any moderator fix it ? with my apologies
I work in real units too, using 'mean sea level' as zero, with the site being set at zero and ground floor at whatever is level is desired. I presume you prefer to 'level' from ground floor = 0.00.
I just tried it and had no trouble entering negative values. I even tried placing a corner below the base of the mesh and the value was accepted (the solid was of course compromised and the top surface only showed in 3D).
Thanks for your answers ! And Hi Mattew
I finally found it in the settings (option menu) there are 3 new reference altitudes available, when you set them (for exemple a zero sea level and a first floor level) these altitudes are available immediately for any level setting and of course for the meshes. You don't need any more to take care of the meshe's personnal reference level.
