2010-02-02 11:17 PM
2010-11-06 05:05 PM
2010-11-06 05:59 PM
The only time I ever heard back from the developers was to be snidely told to upgrade so I could upgrade to a version that fixed the broken library part (pocket door v11).I would like to say that I did later get an apology from the developer who posted the comment that I mentioned here. That was nice.
2010-11-06 06:11 PM
ejrolon wrote:Ejrolon,
The recipe is to use "Layer Sets" and "MVOs" to control how you want to view the model and to create a fill with the pattern you need that is composed of white lines and transparent background. This fill will be overlayed on top of the drawing.
2010-11-06 06:40 PM
2010-11-06 06:42 PM
2010-11-06 06:43 PM
2010-11-06 07:31 PM
ejrolon wrote:Erjolon,
Using Partial Structure Display.
Is this closer to what you want?
2010-11-06 09:37 PM
Would please tell me and the forum how many steps it takes for this solution from creating the object wall to having a working drawing?1. The only wall conditions that you have to create are for different walls widths i.e. 6", 8", 12" etc. It should take the same amount of time as it takes now provided you have predefined the wall widths the first time. For this example doing it for the first time it took my about 5 mins. Once you create your first one and you are happy with it the others should take less than a minute to do since you only have to alter one parameter.
How many different views and fill masks would you need to use for an entire set of working drawings with a complete set of structural plans?2a. 1 View for the normal view, 1 View for structure. Or one view type for the architectural plans and one view for the structural plans.
I ask this because I am concerned with the time…3. It should take the same time as it takes now to define views for different consultants.
2010-11-06 11:13 PM
ejrolon wrote:I may be misunderstanding your process. Here is what I thought that your process is:
2b. No fills or masks needed. I did not do any extra 2d work.
2010-11-06 11:28 PM
4a) Cover the walls in this view with a masking fill that has white blocking hashing to give the walls of the appearance of being dashed lines.This is the missing step all the others are ok. I am using a Composite to fake the dashed line (see image) and using "Partial Structure Display" to control the MVO between structure only and architecture. AFAIK "Partial Structure Display" is not available in AC11.
4b, c, d, e, f...) Draw this fill over every wall that has a unique orientation or curved line.
Maybe this is the step that I am misunderstanding. Please explain your process if is different.
