‎2006-04-27
05:57 PM
‎2023-05-25
06:00 PM
Rubia Torres
‎2006-04-27 06:14 PM
‎2006-04-27 06:20 PM
‎2006-04-27 09:45 PM
rfoxley wrote:using SEO seems to be a very witty decision
check your element priority settings, if the walls have the default priority then they will always show on top unless you manually change them.
‎2006-04-27 09:51 PM
rfoxley wrote:I tried that.... same result as shown in the original problem. Are you just using the Layer Priority? Or changing it somewhere else?
‎2006-04-28 05:31 AM
rfoxley wrote:IME it has nothing to do with any kind of priority. The only priority that comes into play are the 3D Intersection priorities in
‎2006-04-28 06:03 AM
