sloping columns
I am newbie Archicad 14 user (ex Revit)
How do you create a sloping column 2750mm high
ie: Starting as 900 x 400mm wide at the base with sloping front edge to 600 x 400mm wide at the top.
Complex profiles.
Use the object "Offset Column.gsm".
David Maudlin
casacamo:
In addition to the other suggestions, you can use a Double Slanted Wall, leaving one side at 90˚ and setting the other side's angle to 96.2258° in this instance.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
