Govin eric
small wish list
I think beyond the BIM etc. some small day to day tools would benefit with those 3 No improvements:
1- Building materials and library objects should also have the Partial core display as an option.
2- Materials used in Composites & Complex Profiles should have a Renovation option within the tools to allow to draw everything as one slab / wall etc instead of having to create multiples (floor finish/ structural etc)
3- Wall, Beams, Columns, and objects should have the same option as the Slab and Mesh for the story projection (a custom option). Actual options are too limitative.
Best regards
1 Reply 1
Welcome to the forums. I moved this out of the Developers forum - which is for people who program add-ons for AC.
It is best to spend some time in a new forum to understand how the community works before posting. We have special forums here specifically for organizing wishes, which adds voting polls to them. But, if you use the search function, you'll find all of your items have existing wishes for them - and duplicates are discouraged as it then just becomes 'noise'.
Finally, each post/thread/wish here should relate to a single topic that is mentioned in the subject line. Entering multiple topics with a generic subject also means that the post will not receive much attention.
