Sejal Chevli
snap guides are offset
Hello all,
I have this issue in my Archicad file, where all my elements' snap guides in 3d view are offset. Has anyone come across this issue? I know it might be a very simple click, however I can't find out where this setting might be.
2 Replies 2
Lingwisyer
Guru
Hotspots and bounding boxes not lining up is often caused by modelling far from origin. Alternatively it can be caused by a driver issue, in which case sometimes restarting AC will fix the issue.
Ling.
Note: This thread should not be in the sub "What's New?" Probably "Design"
Rubia Torres
Hi @Sejal Chevli,
It does seem like a far from origin issue. Please refer to this article, it will help you find out if you are modelling far from origin and fix it.
Rubia Torres
Community Expert | GRAPHISOFT SE
Need help refining your Archicad skills?
Check our Modeling knowledge base for the best workflow + tips&tricks!
