Learn more
Strawbale23
stair width
Creating a stair using AC27, and I notice that the stair width is 1cm different at the top of the stairs than at the bottom, what could be causing this???
thanks
AC26
https://www.zendsign.fr/
1 Solution
Can't get any more simple than that.
What does the flight width in the stair settings say it is?
And I assumes you have placed this stair by defining the length of the base line (reference line)?
You haven't edited or stretched it in any way?
Is it a rounding issue with the dimensions.
Can you set your dimensions to show more decimal places as a check?
Go to post
11 Replies 11
Steve Jepson
Different in the same view?  Or different in views that might have different dimension settings ?
Strawbale23
Hi Steve, on plan view I have my stairs placed. And when I measure the width of the stairs at the bottom and the width of the stairs at the top. There is a 1 cm difference. This also means that the long edges of the stairs is not parallel.
AC26
Steve Jepson
Just one more reason why I have so little to no use for the Stair Tool.  Things like that can go unnoticed for a while and cause all kinds of problems.  At least you found it.  Good luck with it 🙂
Can you show an image of the stair in plan?
Strawbale23
Hi Barry, here it is:stair mystery.JPG
AC26
Guru
Having dimensions fall on half your dim accuracy is sooo annoying...
Strawbale23
Thanks Barry, you were right, I had accidently stretched it in the cornerby a tiny fraction and had not noticed.
I did not know this was even possible.
AC26
There is the stair baseline (reference line) that controls the path of the stair.
Usually when you select a stair you see this single baseline.
But if you select the stair by the opposite side to the baseline, you will see 2 boundary reference lines.
Stretching these will affect the shape of the stair - make one end wider or curve an edge for example.
