2023-12-10 12:43 AM
Creating a stair using AC27, and I notice that the stair width is 1cm different at the top of the stairs than at the bottom, what could be causing this???
thanks
Solved! Go to Solution.
2023-12-11 02:20 AM
Can't get any more simple than that.
What does the flight width in the stair settings say it is?
And I assumes you have placed this stair by defining the length of the base line (reference line)?
You haven't edited or stretched it in any way?
Is it a rounding issue with the dimensions.
Can you set your dimensions to show more decimal places as a check?
2023-12-10 04:24 PM
Different in the same view? Or different in views that might have different dimension settings ?
2023-12-10 04:32 PM
Hi Steve, on plan view I have my stairs placed. And when I measure the width of the stairs at the bottom and the width of the stairs at the top. There is a 1 cm difference. This also means that the long edges of the stairs is not parallel.
2023-12-10 04:48 PM
Just one more reason why I have so little to no use for the Stair Tool. Things like that can go unnoticed for a while and cause all kinds of problems. At least you found it. Good luck with it 🙂
2023-12-11 02:01 AM
Can you show an image of the stair in plan?
2023-12-11 02:07 AM
Hi Barry, here it is:
2023-12-11 02:20 AM
2023-12-11 02:39 AM
Having dimensions fall on half your dim accuracy is sooo annoying...
2023-12-12 10:44 AM
Thanks Barry, you were right, I had accidently stretched it in the cornerby a tiny fraction and had not noticed.
I did not know this was even possible.
2023-12-13 03:32 AM
There is the stair baseline (reference line) that controls the path of the stair.
Usually when you select a stair you see this single baseline.
But if you select the stair by the opposite side to the baseline, you will see 2 boundary reference lines.
Stretching these will affect the shape of the stair - make one end wider or curve an edge for example.
