stairmaker question
Is there a way to create a single run of a stair with a slab (landing) at each end? i tried to create a custom stair and the only way i could get a slab was to use a u-return with landing. i am trying to model it how it is built. landing - riser - landing
any help would be appreciated
Jeff Hopkin
Project Modeler
Iowa Prestressed Concrete (IPC)
601 SW 9th Street, Suite B
Des Moines, IA 50309
2 Replies 2
Jacek
If I understand your question correctly you want something like the picture attached below.
You need to select Concrete stair in the library and play with "Lower/Upper Joint length" under Parameters.
jacek lisiewicz
arkhos-tekton, architects
carmichael, ca
Mac OS X 10.15.5
IMac Retina 5K, Intel Core I7
32 GIG Memory, AMD Radeon R9
ArchiCAD 24
That works perfect. i would have never looked there.
Thanks
Jeff Hopkin
