strange message
Every time I try to open a section or 3d window I'm getting this message -
"Can't find picture file: pine1, called at line 215 of file master_gdl.GDL."
I can't get rid of it ?
thanks - ittai
4 Replies 4
Rob
mate, you are missing a library part, actually in your case a bitmap that is being called by master_gdl.gdl file script everytime when you go to 3D window. I do not know what library parts you have used in your project so I cannot help you to identify which it is.
However, shortly how to get rid of that message: you need to load an image named "pine1" to your active libraries.
::rk
Stephen Dolbee
Or go to options/materials, find out what material(s) uses that texture, and remove it.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
Steve
You will find it faster by going to Options/Attribute Manager...
Click on the Materials Tab (see attached screen shot)
Sort by textures
Either delete the offending material or change the texture map.
Eduardo Rolon
It also looks as if you are using the ArchiBAM libraries from GDL central and those have problems with AC09. So if reloading the material does not fix it then we have to wait for the updated libraries.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
