2004-11-25 12:38 AM - last edited on 2023-05-25 06:03 PM by Rubia Torres
2004-12-02 12:48 PM
2004-12-03 02:09 PM
2004-12-03 04:59 PM
2006-05-09 09:23 AM
So for a Window with 90 cm parapet, you make it 100 cm high from the bottom of the Wall, enter 10 cm for Subfloor Thickness.
The window will correctly display 90 cm for it parapet.
2006-05-09 09:52 AM
StuartJames wrote:Perfect explanation. We use it the same way. Not just an obscure option
We also use it extensively;
a) commercial buildings (as per Laszlo) to get the bottom of the door above the screed
b) office premises - to get the bottom of the door above raised flooring systems
c) residential - allowing 10mm - 1/2" for floor finishes also allows you to deal effectively with floor strips at changes in covering.
HTH - Stuart
2006-09-12 08:23 PM
2006-11-30 06:12 PM
Srinivas wrote:I'm having the same problem understanding/using this feature.Has anyone ever figured this out??? When I change the Subfloor thickness value the window vertical position does not move accordingly...nothing changes
...I am also having difficulty in understanding the subfloor thickness parameter...
2006-11-30 07:26 PM
2006-11-30 08:44 PM
Peter wrote:Peter,
The subfloor thickness value does not affect the vertical position
of a door or window at all...
