template with standard layouts
Is it possible to have a set of layouts premade in a *.tpl file?
13 Replies 13
Yes
Check out what a good template file can do for you
http://www.archicadtemplate.com/overview_smaller/overview2.html
Eduardo Rolon
AFAIK yes.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
but how?
This may help further -
http://www.aecbytes.com/tipsandtricks/2008/issue30-archicad.html
TomWaltz
dmn wrote:
but how?
1) Open Template
2) Make Layouts
3) Save Template
Tom Waltz
I think you can also do the following:
1. Open Template file.
2. Open Organizer and Open other ArchiCAD file which has Layouts and Master Layouts you want to use.
3. With drag-and-drop copy needed Layouts and Master Layouts into you Template file.
4. Save Template.
TomWaltz wrote:
dmn wrote:
but how?
1) Open Template
2) Make Layouts
3) Save Template
This is what I would like to be able to do, but it doesn't work that way. The Layouts are not saved when you save the template.
I could just make a standard pln that will be used in place of a template. I suppose I would have to make it read only, so it would not be overwritten.
dmn wrote:
TomWaltz wrote:
dmn wrote:
but how?
1) Open Template
2) Make Layouts
3) Save Template
Works for me.
After you have saved the template, when you create a New Project, do you select the new template as the basis of the new project?
Okay, this is wierd. When I open the template from a fresh archiCAD session, the layouts show up, but when I try to start a new file from an existing session, the layouts and the masters are all dropped?
