terrain with spot levels
Hi folks,
Ive got a project here with a site plan with only spot levels. No contours. Having not really used the mesh tool for terrain creation much before, is there an efficient way of creating terrain from spot levels?
Many thanks.
Lukle.
4 REPLIES 4
lukle
You can select your mesh, and with the polygon construction method active (NOT rectangular or rotated rectangle) double click within the mesh, then click OK in the resulting popup dialogue (only option is to fit to user ridges), then select your new point and assign the appropriate Z value.
HTH
Beautiful Stuart, Thanks. How would I go about smoothing out these sharp ridges ive now got?
Thanks again.
Options within mesh tool settings:
o - all ridges sharp
o - user defined sharp
o - all ridges smooth
Thanks stuart,
Already had that set. Might just be I dont have enough points allocated yet. Still not sure if this is how I should be approaching modelling this site.
Lukle.
