2007-12-28 03:52 PM
2007-12-28 05:09 PM
another Moderator
2007-12-28 05:44 PM
2007-12-28 05:53 PM
Create a New Title Typeor if you know GDL Select a title that is already placed in the Layout Book go under File-> Libraries and Objects -> Open Object …
In the Layout window, use the available 2D tools (e.g. lines, text blocks) to design a Title Type to fit your needs. Select the components of this new Title Type. Use File > Libraries and Objects > Save as Title Type to save this object. Once saved, your Title Type is available from the pop-up the Title panel of Drawing Settings.
Once saved, you can subsequently edit this custom-created Title Type graphically: Use File > Libraries and Objects > Open Object. From the directory dialog box, select the Title Type you want to edit. Click “2D Symbol” to access the graphical editing window for this object. Make your changes using 2D tools.
Note: Make sure the scale of the GDL 2D symbol window is set to 1:1, to make editing easier.
another Moderator
2007-12-28 07:03 PM
2007-12-30 05:07 AM
