License outage
Dear Customers, We are facing with an outage in our services in Azure. You may experience issues with the Azure-based functions, like licensing, BIMcloud SaaS, Learn Portal. We are working hard on this issue to make it fixed as soon as possible. Thank you for your patience.
In ACAD 7, one was able to toggle between selection tool and last tool used by hitting the right arrow key. Is there such an action in ACAD 9? It is quite useful.
edog wrote: In ACAD 7, one was able to toggle between selection tool and last tool used by hitting the right arrow key. Is there such an action in ACAD 9? It is quite useful.
In Options/Work Environment go to Shortcut Schemes/Keyboard Shortcuts.
Set the list to All commands by theme
In Folder # 12 (Actions) you will find Arrow Tool/Last Tool Toggle; assign it 1 as a shortcut, overriding the default
