trimming wall in 2d?
can anyone tell me what im doing wrong. i want to trim a wall in 2d on an angle but it will only trim it straight. its driving me nuts. cheers
4 REPLIES 4
this is what i get when i try to trim to the line
NCornia
paulnewsome,
Use the Wall End Tool>Wall End Chamfer 14 object.
That would be a cool feature if you could split a wall on an angle. I think the Objective add-on by Ralph Wessel might do that.
HTH
Nicholas Cornia
Technical Support Team - GRAPHISOFT North America
ARCHICAD on Twitter
Tutorials
GRAPHISOFT Help Center
Thomas Holm
A quick-and-dirty way of doing this is to: (see figure)
1. create a segment of the wall at the angle you want
2. select that segment and make it as thin as possible
Or you can use the Polygonal Wall to make the Wall End.
Whichever of these choices fits you best.
