2020-11-19
05:16 AM
2023-05-09
03:48 PM
Rubia Torres
Solved! Go to Solution.
2020-11-19 10:45 AM
height.tan(alpha) < width height = height of wall alpha = slope of face width = width of wall baseIf you want a specific top width, just input your desired height and wall slope, then add your top width to the answer.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
2020-11-19 08:44 AM
2020-11-19 09:26 AM
2020-11-19 10:45 AM
2020-11-20 01:08 AM
Lingwisyer wrote:I tried either changing to "Basic wall" or "Composite wall", the effects are the same: some times work and some times not work
Does that tutorial actually ask you to use aCompositerather than a Basicwall? Bit odd that it would tell you to use a specific composite with sloped faces / height that does not work...
Ling.
2020-11-20 01:19 AM
2020-11-20 02:28 AM
2020-11-20 09:09 AM
Lingwisyer wrote:yes that's perfect (maybe the turorial is based on other AC version but I am using AC 23 so not all matches)
Odd... Does it also work if you set the wall sides to straight, change the height, then apply the slopes?
