unable to change wall hight
Hello, I am trying to adjust a slanted wall height from 3400 to 3950, but the wall top only changes to 3423,
I tried "clear all connection" but same effect.
Please advice why
Lingwisyer
Guru
Since you are using a Composite, you will need to modify the some of the layer thicknesses within the one you are using, or make a unique Composite for this wall.
That equation is just means that your top thickness is not less then zero.
height.tan(alpha) < width
height = height of wall
alpha = slope of face
width = width of wall base
If you want a specific top width, just input your desired height and wall slope, then add your top width to the answer.
Does that tutorial actually ask you to use a Composite rather than a Basic wall? Bit odd that it would tell you to use a specific composite with sloped faces / height that does not work...
Ling.
7 REPLIES 7
Lingwisyer
Guru
Increase the width of your wall? height.tan(alpha) < width
Hello Lingwisyer, how can I Increase the width of slanted wall? it is a slanted wall with 97 degree angle slanted
and where to set this "height.tan(alpha) < width"?
Thanks
Lingwisyer
Guru
Ling.
Ling.
I tried either changing to "Basic wall" or "Composite wall", the effects are the same: some times work and some times not work
As the attached picture, I follow the same way of the tutorial, one end of wall works, and the other not.
Such not being stable could because of version bug ...
Thanks Lingwisyer
Now I found a process to be stable-- click OK after each step:
(1) ā€wall selection settingā€œļ¼Œchange to basic wall, then click OK
(2) ā€wall selection settingā€œļ¼Œ change height, then click OK
(3) "wall selection settingā€œļ¼Œchange back to composite wall, then click OK
Lingwisyer
Guru
Odd... Does it also work if you set the wall sides to straight, change the height, then apply the slopes?
yes that's perfect (maybe the turorial is based on other AC version but I am using AC 23 so not all matches)
Many Thanks Lingwisyer
