videos on basic archicad drawing principles.
Can anyone put links up showing on line videos of how to draw buildings with archicad. The reference guide only states how to use the tools, not how to draw. Ie create slabs from exterior walls etc
Thanks
1 REPLY 1
I presume you have watched the Interactive Training Guides?
http://www.graphisoft.com/education/training_guides/
(P.S. To create a slab automatically using the external walls as a boundary; select the slab tool, adjust the settings and press OK, hold down the spacebar and left click once in the space between the walls. You should now see the slab if you look in the 3d window!)
Hope that helps!
