visualization of slabs
I have a problem with visualization related to different levels. I draw a slab in ground floor and I tell him to show on all stories (because I want to see it from roof plant), but in fist floor I only want to see current story, so in view settings (of first floor) I tell archicad to see only current story but I see the slab of ground floor because of the settings of the slab. Is there a better way to manage this?
Another problem i have is that when I asign a cover fill to a slab I have to send it back so I can see the objects or even slabs that are above, this is not rational, it´s not real, its not BIM!, i really miss revit in this sence, that when you cut something you see what it is.
1 Reply 1
Guru
Change your Views Cut Plane Settings? From there you should be able to modify whether you will be able to see objects outside of the current story plane.
