wall and column panel design
hi all I'm very new to archicad and while i have learned alot,i find myself at a halt at the moment, i have to create an interior layout of a room and have to use panelling , but not sure how to get the desired effect,.. i have the wall and panel covering addons, but still cannot get the desired look any help is much apprecicated.. hope its not a dumb question
here's a sample of what i need
6 Replies 6
Eduardo Rolon
Try using the Curtain Wall tool, specially if you are in AC22 instead of regular walls and coverings.
https://helpcenter.graphisoft.com/tips/archicad/how-to-create-cladding-using-the-new-curtain-wall-to...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Carstenem
this will work just fine, see markup.
Carsten
www.asmtechbase.com
https://www.youtube.com/asmtechbase
AC 3 to 26 -Windows 7 - 24GB - 8core 4.4Ghz
Lingwisyer
Guru
If you use Wall Profiles as in Carstenem's option, you will need to model in all of the horizontal divisions between your panelling unless it is included within your texture. This might create a discrepancy between your horizontal and vertical divisions though.
Ling.
Then in that case what do you recommend...
btw thanks all for the replies
If you have version 22 then use the curtain wall as Eduardo suggested.
It will create all of the horizontal and vertical joins (frames) and all the different panels.
It might be possible with curtain wall in older versions as well (I am no expert with them), but it is definitely possible in 22 as the curtain wall tool is much improved.
Carstenem
Yes AC22 curtain wall would be the best option, at least it looks like it watching the new videos, here Down Under we still wait for AC22 lagging behind !
Carsten
www.asmtechbase.com
