wall closure not working in projected display
Wall closure does not work when I turn the symbolic floorplan view in windows to projected view. Screenshots of the view are attached.
Also, how can I make the glass get represented by single line instead of two in floorplan. Pls help
13 REPLIES 13
As you can't upload two images in one post, I am adding the second one for projected display image.
I think you uploaded the same PDF file twice.
There is a way to post many pictures in the same post. You might not want to do it but I can tell you how if you like.
Attachment changed.
Yes, I would like to know. Pls tell me. As of now, I am more concerned about my problem.
Thanks.
But my problem is how to show plaster wall closure when window is in projected display mode.
Like shown in this video
Wall closure
ishpalsingh wrote:
Thanks.
Yes, I was trying to show you how you might communicate with pictures better so we can help you.
Like I said before, I am not sure what we are seeing is not as expected.
Projected and Symbolic should display differently. MVO might also be a factor?
That window is from the International Library which I don't have for version 20. So I a don't think I can be of any help. Sorry.
Line marked in blue shows plaster turns which i want.
Also, how to show single colored line for glass instead of two
It looks the same for me in Symbolic Cut and Projected
