2010-11-17 06:24 PM - last edited on 2023-05-25 05:45 PM by Rubia Torres
2010-11-17 10:39 PM
2010-11-17 10:48 PM
2010-11-18 12:24 AM
NCornia wrote:
Homayon,
Sounds like a cut plane issue. You cannot see the wall because the cut plane on the story you are looking at in floor plan is below or above the wall now that you have moved it.
Either change your cut plane or move to the appropriate story to view the wall correctly. If the wall should indeed be listed on a new story you will need to change that in the wall settings.
HTH
2010-11-18 01:39 AM
2010-11-18 01:40 AM
2010-11-20 02:41 PM
s2art wrote:NCornia and s2art thank you very much
Wall settings...
