‎2008-05-26 11:44 PM
‎2008-05-28 02:51 PM
‎2008-05-28 03:45 PM
another Moderator
‎2008-05-28 03:53 PM
‎2008-05-28 03:58 PM
ejrolon wrote:sorry, i disagree... i think the walls that are on the same plane should BE on the same plane and reference lines on the same side: outside. Then the perpendicular wall needs to be connected onto that point....carefully.
The Problem is on how you connected the walls. Difficult to explain clearly, but basically you have to connect first the Main walls and then the balcony.
‎2008-05-28 04:35 PM
‎2008-05-28 05:27 PM
zoltar wrote:edit/ reshape/ adjust
By connect I assume you mean draw or some other procedure? First I drew the outer wall and then the balcony wall. This is what you mean,no?
