aggie463 wrote:
not sure i understand exactly how wall priorities work..what exactly would be the correct priorities for this intersection to be accurate?
back up a little . . .
do your wall reference lines meet? and are the fill-types for each skin the same?
regarding priority intersections, the
principle
 goes something like this:
structures with a higher priority will block structures with a lower priority. identical priorities will cleanly mitre if they're the same fill-type. (i think . . . or at least hope). the
reality
 is much different since archicad's priority system isn't flexible enough, nor thoroughly implemented, in order to cover all possible intersections.
i base my composite structures - and beams/columns - on the following priority principle...
0	- Finish : Secondary				- wet finishes such as paint, plaster, etc
2	- Finish : Primary				- dry/panel finishes such as boards, sheet cladding, etc.
4	- Thermal/Air Space				- all solid insulation skins plus non-core voids, cavities and air spaces
6	- Membrane					- solid membrane skins such as asphalt, rubber, sarna etc.
8	- Substrate/Strapping			- boards such as ply, particle, MDF, etc. and straps, firring, top hats for fixing
10	- Cavity/Air Space				- core-only voids, cavities and air spaces
12	- Wall Structure : Beam Priority		- bearing elements such as solid concrete, timber & steel frames, masonry that beams intersect
14	- Wall Structure : Wall Priority		- bearing elements such as solid concrete, timber & steel frames, masonry that beams abut
16	- High priority bespoke use		- use for walls to manually override beam priority '15' and wall priority '14' elements
Beam Priority Values
 1	-
3	-
5	-
7	-
9	-
11	- Beam Structure : Wall Priority		- Secondary structural frame elements that abut structural (12) walls and columns
13	- Beam Structure : Beam Priority	- Primary structural frame elements that intersect structural (12) walls and columns
15	- High priority bespoke use		- use for beams to manually override beam priority '13' and wall priority '14' elements
Column Priority Value
12	- Structural Columns Only			- Due to inflexible archicad column priorities, use column tool only for structural elements!
does this help . . . or confuse you more?!
~/archiben
	b e n _ f r o s t
