ā2007-02-07 04:40 AM
ā2007-02-09 04:03 AM
KeesW wrote:that is indeed the ideal development direction for this type of thing: 'physical' material definitions that automatically take their attributes through to any required level of interaction within the model. until then, i remain a faithful masochist: working my skin definitions based on the hierarchy i outlined earlier . . . and leaving only number 16 available for the commercial-environment-friday-afternoon-issue-manual-over-ride times . . .
Or default priorities could be automatically determined by the materials used. For example, internal plasterboard lining are always connected. Brick or block walls always connect rather than being interupted by a plasterboard layer. Note I used the word 'default'. The option to alter priorities should probably remain available for masochists, refined intellectuals, or those with lots of time working in a non-commercial environment.
ā2007-02-09 09:42 AM
KeesW wrote:I am afraid that I have to agree. All the various intersection controls are desirable features, but they should remain in the background while walls generally work as they should and be invoked (resorted to) only in the exceptional cases as needed. Of course I think this is how all software should work - unfortunately very little actually does.
I am sorry to say this but wall priorities are a nightmare...
ā2007-02-09 12:19 PM
~/archiben wrote:I agree with your approach. Most of my composites are a legacy copied across from previous versions. Unfortunately the way that 10 treats these is not as reliable as it could be. The lesson I think is to re-create the composites with due care in version 10.
... philip - i rarely use a plain ol' vanilla wall as a wall anymore. i define composite structures for walls containing even only one skin. ...
... what's needed is a bit of rigour when setting them up and expanding them . . .
~/archiben
ā2007-05-18 02:52 AM
ā2007-05-18 04:07 AM
ā2007-05-18 10:40 AM
s2art wrote:
Kees
The key is Layer Combinations.
You should have a layer combo assigned to each view (existing and proposed). Edit the wall priorities in each combo so that, for existing plan proposed walls (turned off) have a different priority to existing ones. In the proposed plan combo, existing and proposed walls have the same priority. Don't forget to hit the Update button when changing the layer combo's.
ā2007-05-18 02:55 PM
ā2007-05-18 05:39 PM
KeesW wrote:It used to be! About 4 versions back. Thankfully it still is basically intuitive in the core areas, like the tool box, the layer sets and the layout book arrangement but it has become a VERY complex tool and with that comes a whole lot more learning.
Thanks Philip and Stuart
Archicad is sometimes not very intuitive, is it?
ā2007-06-24 12:50 PM
ā2007-06-24 01:48 PM
nats wrote:You might look at the "orientation" options when you are setting up a component of a composite wall.
IE: is there anything I can set in Archicad that will automatically rotate the hatching to suit the wall orientation? You would think the composites would be programmed to automatically rotate their hatching to suit their orientation but they dont!
Nats
