2007-02-07 04:40 AM
2008-06-30 09:51 PM
2008-06-30 10:03 PM
2008-06-30 10:44 PM
2008-07-01 12:31 AM
~/archiben wrote:I hear you. I had them as several separate walls initially, but it really wreaks havoc on the window schedule because you have to have separate window openings to penetrate all of those interior "walls". Unless I'm missing something. There are some work arounds for that ... but I really wanted to try to get this thing to work.
personally, i wouldn't try to lump so much all on to the one wall. i would create the mouldings and panels as a separate profile. complex profiles are still in their infancy: you will have more luck intersecting two identical profiles. it's taken graphisoft 20+ years and they still can't get orthogonal composite walls and slabs to intersect - do you honestly think they're going to get "complex" shapes intersecting straight off of the bat?!![]()
sure there is extra work involved in maintaining two walls, but since you're about renovation the exterior wall (structure) is likely to remain static: by creating the moulding and panels separately you get to swap them out for different ones without having to mess with the whole wall. you also have the flexibility of 'cladding' some rooms and not others and using the same profile across projects?
just a thought . . . ?
~/archiben
2008-07-01 12:42 AM
mc0m wrote:there are: ensure all of the empty openings have no ID or a specific ID that can be excluded - that will sort it out quickly.
... but it really wreaks havoc on the window schedule because you have to have separate window openings to penetrate all of those interior "walls". Unless I'm missing something. There are some work arounds for that ...
2008-07-01 01:03 AM
~/archiben wrote:This is the first I've heard of this ...
does the wall accessory 'moulding and panels' - attached by way of zone/room accessories - not work for you?
~/archiben
2008-07-01 01:15 AM
mc0m wrote:make sure that you've downloaded the 'accessories', 'accessories library' and 'interior wizard' from GS's website.
This is the first I've heard of this ...![]()
2009-06-17 07:27 PM
2009-06-18 11:05 AM
2009-06-18 11:17 AM
