walls problems
I am a new user of ArchiCAD 22.
My problem is that when I draw a wall (simple rectangular shape) and then move the model, the walls of the corner protrude.
The same model shows ok if in a different position.
Please look at the images.
I cannot understand where is the problem.
Thank you,
El
2 Replies 2
runxel
Could have several reasons.
Most commonly:
• Badly drawn model (lacking precision)
• Multiple walls in the same place
• Walls of different heights meet
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
Other elements in hidden layers could be affecting how the walls have trimmed.
Or you did not move the entire model (again there may be elements in hidden layers you did not move?).
