2012-04-05
12:49 AM
2023-05-24
12:57 PM
Rubia Torres
2012-04-05 12:55 AM
2012-04-05 01:00 AM
2012-04-05 03:32 AM
2012-04-05 02:10 PM
Erika wrote:To use the Floor Plan Cut Plane, the Wall's Floor Plan Display must not be set to Symbolic Cut, and the Show on Stories should be All Relevant Stories.
Try adjusting the cut plane settings, how far up/down you see in the View settings.
2012-04-05 06:05 PM
2022-01-10 03:20 PM - edited 2022-01-10 03:21 PM
Digging up another older tread. Almost a decade old!
I have walls on storey 4. They continue up from storey 4 only.
Below storey 4 is storey 3 and 2. The particular wall does not cross either of these storeys.
Then, on Storey 1, I need to create a ceiling plan which should show the walls of storey 4.
I can't seem to figure out how to do this.
In short:
I need to show walls which has a home storey 3 storeys above the storey I need to show them on.
Any advise would appreciated.
2022-01-11 03:37 AM - edited 2022-01-11 03:40 AM
Change your FPCP settings to show 3 above for that plan View with the walls you are wanting to show set to Relevant Stories? That is if you do not have anything on stories 2 and 3 that are set to Relevant Stories...
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2022-01-11 02:35 PM
Thanks Ling, that works.
Here are the settings I used.
