window in curved wall
i want to put a window on a curved wall.even i marked the curved line in model at window default setting but it does not work.i put the window and it is straight not curved. do i miss anything.
AC 8.R3
4 REPLIES 4
AC 8.R3
If you want to place a curved window in a curved wall, you'll have to select a specific curved window.
They can be found in Basic Library -> 1.3 Windows -> Metal windows -> curved window
Link
That's right - and you get to choose from all one of them
Link.
hi,thanks for the reply.but do you think i must only use the curved metal window?
if so, what is the use of the two botton in model at windows default setting? how can i put other type of windows?
While not the best solution, but still a workaround, try making the curved window using Profiler. Should only take 5 minutes or so and then you have the window for future use as well.
Grant
