2023-07-03 06:03 AM
Hi there,
Ive tried to insert a window into a single skin composite but its showing up like an empty opening and not a window. When i select the window and go into properties its showing the 3d view and 2d view as a window but in floor plan and 3d its empty?
2023-07-03 07:12 AM
Check Your Model View Option settings for the display of windows.
This will affect what you see in the model, but not what you see in the window settings.
2023-07-03 08:21 AM
Hi Barry,
Thanks for getting back to me. It doesn't seem to be MVO issue as the windows on the external composite of the model are viewing correctly?
2023-07-03 08:47 AM
The only other thing I can think of is it has a renovation status that is currently set to 'hide'.
