Chadwick
window wall contours and corner options
Ok, I have two questions here that I cant seem to figure out. First, how do you change the pen for the wall contours in a window? I see the option to turn them on and change their line type but nothing to change their actual pen (it appears that they are pen #10).
Also, is there a way to get a ribbon window to go around a corner if its set back 3" into the wall? If its flush with the wall face its easy - take the two windows and turn on their corner options and it looks wonderful. But if the windows are set back, there is a remainder left at the corner.
Any ideas?
RA 2012 x64, Piranesi 6 Pro, Sketchup 8, Windows 7 Pro x64, Intel Core i7, 10GB RAM, ATI Radeon Mobile 5870
13 Replies 13
Problems like these were intended to be solved by introducing the Corner-Window tool but due to number of constrains with this tool it barely suits it purpose. Hopefully we’ll see some progress with this issue in future.
Don't hold your breath.
I wonder what level of testing functionality Graphisoft go through. By simply using the part it is obvious that there is an issue. So many parts have bugs or issues that a simple testing procedure would reveal.
I am still waiting for these parts to be fixed even though I brought it to the attention of Graphisoft six months ago.
Door panel style 1 when "Opening Line in 3D" is selected
Threshold length for a door set to nominal opening
D1 Storefront 3 10
D2 Storefront 3 10
D2 Storefront 1 10
W Storefront 3 10
D1 Entrance Side 1 10
D Curtain Wall Doub Door 10
D Curtain Wall Door 10
Vent Window
W Niche 10
No Awning Windows
Greg Kmethy
Graphisoft Alumni
Graphisoft Alumni
sam66,
The Australian library update has been posted today. Hit "check for latest library" in the Help menu.
Greg
Gergely Kmethy
VP, Customer Success, Graphisoft
gkmethy wrote:
sam66,
Greg
Excellent
