2019-10-05
02:44 PM
2023-05-11
11:05 AM
Noemi Balogh
Solved! Go to Solution.
2020-02-06 07:21 AM
Steve wrote:
Step one for me will be getting the ArchiCAD element/s to be displayed in Rhino via the ArchiCAD-Grasshopper add-on.
I have still not been able to do that using ArchiCAD 23 and Rhino 6 - but it was working for me with earlier versions. I must have some simple thing setup wrong. ? Connections are verifiably established but I do not see anything in Rhino.
2019-10-21 05:40 PM
2020-01-17 12:57 AM
2020-02-05 10:52 AM
Steve wrote:Have you tried to add in parameters in Grasshopper to assign your ArchiCAD elements to?
2020-02-06 07:21 AM
2020-02-06 08:16 AM
2020-02-06 08:27 AM
2021-11-12 05:04 PM - edited 2021-11-16 07:36 AM
_
2022-03-29 04:17 PM
Hi Daniel,
I am having an issue with the connection with Rhino 7 and AC25 latest build, that happened after I uninstalled Rhino 6 this morning. The connection is detected, all the AC nodes become grey, but I am not able to send anything, and all the attribute nodes as well as any node that requires connecting with AC don't collect any data (like the GDL object library). I have deleted the connection plugin and reinstalled it, also uninstalled Rhino and re-install and nothing... quite frustrating though.
Any idea or advice?
2022-04-05 02:52 PM
Hi Jorge,
Did you find a solution to this?
I am having the same issue. Running Rhino 7 and AC25 on a Mac studio (M1 max chip)
Marius
