2021-03-25
12:44 PM
2023-05-25
09:07 AM
Noemi Balogh
Gordana Radonić
Community Manager
2021-04-24 12:52 AM
Mjules wrote:I don't know what you mean? It is a free download - download it and play with it
Is this a free wall, karl?
2021-04-24 02:10 AM
Karl wrote:Sorry, Karl! I should have said free-form wall.
Is this a free wall, karl?🙂
2021-04-24 11:41 PM
2021-04-27 05:27 PM
Karl wrote:I hope so too. What is the expected workflow for US users? Convert metric for use in PARAM-O or Grasshopper, ArchiCAD, Rhino connection? I have only spent a few minutes on PARAM-O but I already know it will be easier to integrate into our workflow because the script components use the same terminology as archiCAD. I know you can do anything in the world with grasshopper but to me, that's kinda what makes it so hard to learn, imo
Not yet. I hope it is at the top of their priority list. The argument is that GDL and the internals of ARCHICAD are all metric, however the fact that we can actually enter feet and inches (FFI) while coding GDL itself makes that kind of irrelevant. Seems to me that PARAM-O should honor the working units and allow entry in whatever the current working units are.
2021-05-12 09:44 PM
Karl wrote:Yes. And it would not hurt to have more units of measure available as Calculation Units in the program without having to use any expressions/coding.
LowFalutin wrote:Not yet. I hope it is at the top of their priority list. The argument is that GDL and the internals of ARCHICAD are all metric, however the fact that we can actually enter feet and inches (FFI) while coding GDL itself makes that kind of irrelevant. Seems to me that PARAM-O should honor the working units and allow entry in whatever the current working units are.
It seems like my model units in param-o are in SI / Metric units. Is there a way to use param-o in feet and inches?
2021-05-12 09:48 PM
Gordana wrote:My first observation about PARAM-O is that unless I can import geometry into the PARAM-O modeler, I am not so enthused with it as I would be if it could do that. I assume plans are underway to make that possible ?
Hello everyone,
Have you started using PARAM-O? What are your impressions, experiences so far? Any examples to share?
I am curious to hear what do you think about it.
Kind regards,
Gordana
2021-05-12 10:14 PM
2021-05-13 04:20 PM
Podolsky wrote:But the code Param-O generates, feels a lot like the code we got out of those 2000-ish visual website generators, since it is littered with XFORMs and what not. Hard to comprehend, so not the easiest thing to learn GDL with.
My opinion that PARAM-O is quite limited in term of modelling capabilities. PARAM-O is generating GDL script, that later ArchiCAD is reading.
Knowing GDL well - it's possible to achieve much faster better results. But only if you know GDL well.
But it's good tool to start learning GDL.
2021-05-13 08:17 PM
2021-05-18 09:37 PM
Steve wrote:To answer my own question - we already can get other geometry/models into PARAM-O -- so long as it is converted into an ArchiCAD object first. No problem. We already have good tools for doing that.
Gordana wrote:My first observation about PARAM-O is that unless I can import geometry into the PARAM-O modeler, I am not so enthused with it as I would be if it could do that. I assume plans are underway to make that possible?
Hello everyone,
Kind regards,
Gordana
