Parametric design
About Rhino & Grasshopper and PARAM-O.
Randomize Materials
I am just starting to play with the connection plugin and see that V20 has many more parameters to play with. I am currently doing a randomized facade that is working well. However I am wanting to randomize the colour of some fins between two different surface materials. Any thoughts as to which grasshopper component will allow me to plug different surface or composite inputs into?
As an aside the my Archicad points dont seem to be translating into grasshopper points like they should. They seem to shift in strange directions. What could be affecting this?
Thanks
Derek
31 REPLIES 31
Would you want to continue this topic in a new post that I can write with a bit more detail?
leceta
yeah, it's a good idea...
