2008-08-22
02:19 AM
2023-05-30
01:12 PM
Rubia Torres
2008-08-26 03:42 AM
matthewjj wrote:I have to disagree with that one. I don't think any of us hard-core beta testers use the Graphisoft template other than when they want a bug reproduced. I find the US template pretty sad, bordering on worthless. Further, the template delivered to customers has rarely been the one we saw during testing; 12 may be an exception. No input that we provide ever seems to make it into the template.
My experience is that you are better off recreating your own template file from the factory installed template that comes with archicad.... The one that ships with it does get well tested out during beta phase.
2008-08-26 03:50 AM
2008-08-26 06:22 AM
Karl wrote:While I may not be a 'hard-core' beta tester, I have beta tested the last 4 versions of archicad. And have helped transition our office through the last 5 versions of Archicad. My day job prevents me from being a more frequent poster here in the forums.
I have to disagree with that one. I don't think any of us hard-core beta testers use the Graphisoft template other than when they want a bug reproduced...
You can successfully migrate your templates up via editing and using Attribute Manager to assure that your attributes coincide with those defined by GS for linetypes, fills, and materials - the key ones that are used by the library.
2008-08-26 06:29 AM
Link wrote:
In fact I think the biggest concern is migrating old work environment profiles or schemes that don't include the newer ArchiCAD commands.
2008-08-26 06:42 AM
2008-08-26 07:18 AM
2008-08-26 07:25 AM
Link wrote:Could you elaborate on what you mean by 'opens it up to errors'?
Not only would it take me about a week, but it opens it up to errors.
Keep in mind that templates I create typically contain anywhere between 200-300 prelinked views, full documentation and publishing sets, amongst hundreds of other settings.
As I said, the only thing that concerns me is migrating the Work Environment, as you also discovered.
2008-08-26 07:39 AM
Link wrote:Actually, because I have had this policy of using the AC template to build from I have always had the proper menu items and such. The thing that is interesting about the example of the Space Navigator is that when I opened any project file that originated from AC10 to transition it into AC 11, Space Navigator would not work at all (this happened while using my AC11 graphisoft provided work environment with all the proper menu items).
Have been thinking about this some more and wanted to help you get to the bottom of it, and save you countless hours of work in the future.
2008-08-26 07:45 AM
2008-08-26 04:34 PM
matthewjj wrote:Matthew,
It was during the same AC version transition that I noticed our office standard work environment did not include any of the new AC11 features like Virtual Trace in the menu bars. Why? Because if you don't start with the graphisoft template you will have no idea what you are missing.
