Project data & BIM
2nd Headline for Index
fowebe
Good day! Is there a way for me to create a 2nd headline after the Subset Name like this:
Subset
>  Layout
   >> Drawing1
   >> Drawing2
   >> Drawing3
>  Layout 2
   >> Drawings in Layout 2
Subset
>  Layout
   >> Drawings in that Layout
Thanks in advance!
Phoebe
_________________
Phoebe Lim / Architect
AC26 • Windows 11
9 REPLIES 9
Eduardo Rolon
Like this?
If so click here
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
Hi Eduardo! Thank you for your answer! However, my options look different.
Phoebe
_________________
AC26 • Windows 11
Eduardo Rolon
I think that what you are missing is creating Folders in Layout so that you can add "Subset Name" to the Index criteria
AC27 US/INT -> AC08
another Moderator
fowebe
Hi! I do have Subsets. Just not the option to make it a secondary headline.
Phoebe
_________________
AC26 • Windows 11
Phoebe
_________________
AC26 • Windows 11
Eduardo Rolon
In the Index Scheme settings you have added Subsets?
Sections and Elevations need to be in their own folders.
AC27 US/INT -> AC08
another Moderator
I want the Layouts grouped in: Architectural, Structural, Electrical, etc
Phoebe
_________________
AC26 • Windows 11
Eduardo Rolon
Ok got it, my Bad
First option, but you want and extra headline under architecture
Second Option using Custom Text to add the second Field:
Third Option for more complex projects and which is the one I prefer is to create an Index for Architecture and another for the consultants:
AC27 US/INT -> AC08
another Moderator
I opted for a new Custom text Column, then hide (column width = 0) the Layout IDs (can't remove then cause I need them for Arrangement) and added empty & nameless views on each Layout for Custom Rows at the top.
Thanks so much, Eduardo!!!!
Phoebe
_________________
AC26 • Windows 11
