2024-01-19 05:24 PM - edited 2024-01-22 02:16 AM
Good day! Is there a way for me to create a 2nd headline after the Subset Name like this:
Subset
> Layout
>> Drawing1
>> Drawing2
>> Drawing3
> Layout 2
>> Drawings in Layout 2
Subset
> Layout
>> Drawings in that Layout
Thanks in advance!
2024-01-19 05:43 PM - last edited on 2024-01-25 12:52 AM by Laszlo Nagy
Like this?
If so click here
another Moderator
2024-01-22 02:38 AM - last edited on 2024-01-25 12:52 AM by Laszlo Nagy
Hi Eduardo! Thank you for your answer! However, my options look different.
2024-01-22 12:32 PM
I think that what you are missing is creating Folders in Layout so that you can add "Subset Name" to the Index criteria
another Moderator
2024-01-22 12:55 PM - last edited on 2024-01-25 12:53 AM by Laszlo Nagy
Hi! I do have Subsets. Just not the option to make it a secondary headline.
2024-01-22 12:56 PM - last edited on 2024-01-25 12:54 AM by Laszlo Nagy
2024-01-22 08:07 PM
In the Index Scheme settings you have added Subsets?
Sections and Elevations need to be in their own folders.
another Moderator
2024-01-23 08:54 AM
I want the Layouts grouped in: Architectural, Structural, Electrical, etc
2024-01-23 01:05 PM - last edited on 2024-01-25 01:12 AM by Laszlo Nagy
Ok got it, my Bad
First option, but you want and extra headline under architecture
Second Option using Custom Text to add the second Field:
Third Option for more complex projects and which is the one I prefer is to create an Index for Architecture and another for the consultants:
another Moderator
2024-01-23 06:36 PM
I opted for a new Custom text Column, then hide (column width = 0) the Layout IDs (can't remove then cause I need them for Arrangement) and added empty & nameless views on each Layout for Custom Rows at the top.
Thanks so much, Eduardo!!!!
