2013-06-17
06:36 AM
2023-05-26
03:53 PM
Rubia Torres
2013-08-07 11:03 AM
2013-08-08 10:35 PM
2013-08-08 10:50 PM
Rasmazzer wrote:You have more than one due to priorities, lines weights, line over rides, defaults tool settings etc ... all being slightly different in the migrated file. Maybe things you didn't realize had slight differences. It is really simple to fix. Figure out which one you like the best, and delete/replace the others with that one. However, you might actually need a few that are very similar, but vary slightly as above. I always end up with several concretes, and I only use one. The others are from default tool settings, ones I never use. Pretty quick fix though.
I've started today with cleaning up my template and therefore also the building materials list.
2013-08-11 11:39 PM
laszlonagy wrote:Thanks for response. But in such a case the same restriction would have stopped me from creating new materials or duplicates of existing ones - wouldn't it? and this I can do. Will check tomorrow anyway, hope you are right. Thanks again!
Maybe the Role you are using does not allow you to modify Building Materials (or any attributes for that matter).
2013-08-13 02:38 PM
2013-08-13 04:34 PM
2013-08-20 10:26 AM
Erich wrote:I hear and feel your pain Erich (and others)!
I am just starting to create a template for the new AC 17 and am now attempting to wrap my head around the building material attribute. Does any one have a clever idea or best practice for organizing this new attribute?
While it seems to fix a number of things and is quite powerful, it also seems like it could get unwieldy quickly if not well managed.
I am hoping the community (at least the beta testers) might have some good information to be shared.
2013-08-20 11:23 AM
2013-08-20 12:50 PM
fuzzytnth3 wrote:If you hover over the warning icon there is an indication that legacy mode is currently on. You can turn this off under Project Preferences > Construction Elements.
As this topic is about Building Materials I hope it is ok to ask if anyone can explain why I have a warning triangle displayed next to the Surface pop up
2013-08-20 01:54 PM
