davdelven
Building Material (ALL) values on a Property in Property Manager
Does someone remember if there is a way to create a property within the "Property Manager" that renders the same set of values as the ones using the "Building Material (ALL)" parameter within the Schedule feature?
David Delgado Vendrell
http://www.daviddelgado.cat
GIGABYTE AERO X16 16" AMD Ryzen AI 7 350 32GB 1TB SSD White Copilot+ RGB
Triple Monitor 16"+25"+32" Nvidia Geforce RTX 5060 8GB
SSD+HDD, Win11 Home - 64 ENG
AC18-AC28 INT/SPA (64-bit, latest build)
Surfing with Archicad since 2013
I decided to not switch to the Subscription path, and stay with AC28 proprietary license. We'll see what the future brings us...
1 Solution
Hi David, the "Building Materials (ALL)" general parameter is not available directly in properties.
But it is available in the IFC Property Mapping for the translators, so you can create a mapping rule for each element, see below:
www.graphisoft.com/en-gb/partner-solutions/airc-digital-openbim-services/ co-founder /Operations Director /BIM Lead @ www.airc.digital ltd ™
M Architecture & Urbanism
Archicad 29 ARM, MacBook Pro M3 Max 128Gb, macOS Tahoe.
Go to post
3 Replies 3
davdelven
Thanks, Jaime!
I totally forgot that workaround... even having spent hundreds of hours in the past mapping properties using the translators.
I hope a more robust harmonization and automation is implemented in the future.
This is almost good, but here comes the next step:
I would like to split the ; separated string into bullet point list.
Any idea how to do that?
Basically I would like to do a wall type list and list the wall buildup (building materials) as a bullet point list, simply because this ; separated list is very hard to read.
Any help would be much appreciated.
ArchiCAD since 4.5
Windows, Mac
